Results 16 to 20 of 20
Thread: Advice on Gasless MIG welders
9th Jan 2007, 01:29 PM #16New Member
- Nov 2006
- sydney
- 3
tutorial
Im at the point of wanting to get into doing some welding and fabrication in a DIY manner so a tutorial and guidlines of what to use and how best to use it would be really helpful for me and im sure plenty of others.
Look foward to it if you have time Grahame
cheers
dave
9th Jan 2007, 01:55 PM #17New Member
- Jan 2007
- Covington, Virginia USA
- 2
Hey Peter and all the rest, there are some difficulties with a "small" mig, duty cycle being the major. Lack of "heat" settings would be next. As far as big jobs, multiple pass with my $225 cheapie has proved to be a lifesaver on several occasions. As far as thin sections are concerned, a "copper spoon" (solid copper chunk that is held to back up the section being welded, copper won't stick to weld) will shield and heat sink at the same time ( www.eastwood.com) AND, have you ever tried using a filler rod with the mig welder???? Use it like a steel brazing rod, add the filler as the puddle starts to form, the filler cools the weld slightly and adds additional metal to prevent "burn thru" Lean the rod into the point where the mig wire contacts the base and I have found it best to weld backwards, the gun pointing to where the weld is (new weld) rather than where it ain't. Buy what you can afford and learn to make it work for you. Good luck!!
mobjack68"Too old to be this useful, Way too useful to be this old"
9th Jan 2007, 06:17 PM #18
Graham
You forgot to mention bottles is for beer cylinders is for gas.
Always interested in your informative posts.
If only it will help my welding, thats a lost cause.
I was also taught using both flux core wire with a shielding gas.
A great mig always on my wish list but a stick welder is sitting in the shed.
Pulpo
9th Jan 2007, 09:56 PM #19
yes graham would like to see it also l still like my little gasless mig its quick and easy
smile and the world will smile with you
14th Jan 2007, 11:24 AM #20Intermediate Member
- Dec 2006
- Outer East - Melbourne
- 37
I agree gasless setups have their place. I just see people dissapointed so often when they want to do panel steel with a gasless and it all turns to doo doo. They get angry and upset and sometimes totally withdraw from doing something that may have been quite a pleasurable experience for them.
When I say gasless is a waste of money I am being more specific to anyone that wants to do car body work. If the machine suits your other applications, great. I will now humbly say I have no experience with those other applications, except with a MIG.
Today I am finishing putting integrated 3/4 chassis rails into a Chev V8 converted old Holden. The small MIG I use quite easily achieves the quality required for my work to be approved and certified by an engineer, as required by the registration authority.
MIG pulse welders
By vin in forum WELDINGReplies: 12Last Post: 22nd Dec 2008, 10:35 PM -
Current set up for your Mig
By Grahame Collins in forum WELDINGReplies: 23Last Post: 7th Jul 2006, 11:29 AM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM -
Welders - Difference Between?
By HappyHammer in forum WELDINGReplies: 21Last Post: 11th Mar 2005, 09:41 AM
