Results 1 to 15 of 15
Thread: welding to hydraulic ram
8th Nov 2015, 01:28 PM #1
Hi all.
Just found something new to occupy my time, my new to me, backhoe. Not the fastest thing around, but with a bit of commonsense I recon it will do the job.
As one would expect for something of its age, theres some issues with her that will need addressing.
Doesnt look like its seen a gease gun for quite some time. Regreasing and the usual dumping of fluids and filter changes is at the top of the list.
Anyhow here's a couple of "quality repairs" that I will need to fix. Some of the welds havent rusted, so my assumption is ss rod has been used on some of the repairs.
My thoughts are (but am definetely open to suggestions) is to remove any [hard chroming?] from weld area before rewelding any replacement bits.
pic 1 is my first job
Pic 3 isnt as bad, but dont want to wait too long before effecting any repairs.
pic 2 and 4. Thinking seriously about removing bush and welding in a fresh one. Maybe tack replacement into position with everything in place? Whoever did these "repairs" didnt believe in grease points, so those will included as part of the fix.
Anyone know if "yolk?" in pic 1 can be bought as an off the shelf weld on bit?
Suggestions welcome.
Thanks in advance,
JattFrisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
8th Nov 2015, 01:40 PM #2
my bad pic 1 is actually no. 4
For interests sake, here's a couple of fotos of the Yellow Peril.
Havent been able to find much on the loader and hoe attachment, which appears to have been done by Cranval here in Aust.
Like the idea of the plastic bits that are holding the teeth in place. Hoping they will be easier to replace than something that's weld on.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
8th Nov 2015, 07:55 PM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Nice little machine, fairly sure my neighbour has one on a fordson major carrier.
I have a feeling that the clevices were originally threaded onto the rods, (note the set screw and lock nut), however they probably worked loose over time and copped a weld. All I would do is grind out the old weld, extend the cylinder, give a bit of preheat and lay a nice hot weld with some low hydrogen sticks with a mig as a second choice. If a clevice is too far gone, then a new one could easily be made out of some heavy flat bar or plate.
As you no doubt realise, the old girl doesn't warrant a full line boring job and as such, I reckon that your best way forward will be a combination of oversize pins, oversize bushes and lots of grease to produce a usable backhoe without too much play in the links.
Cranvel was taken over by Connor Shea if I remember correctly.
8th Nov 2015, 08:27 PM #4Philomath in training
- 6,563
Probably worth noting that if the clevis is welded on then the cylinder will probably not be able to be disassembled to replace the seals in the gland. Could be worth putting new ones before hand?
Depending on how much heat shunts up the rod, perhaps the wet rag trick to help prevent seal damage?
(Disclaimer - I have never welded hydraulics before so this is a WAG on my part)
8th Nov 2015, 08:31 PM #5
Mines a British Leyland 154. 4 pot 1500 CC donk.
I have a feeling that the clevices were originally threaded onto the rodsFrisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
8th Nov 2015, 09:28 PM #6Most Valued Member
- Sep 2010
- Lebrina
- 1,916
I would expect that any threads will now be somewhat useless now, hence the welding. New seals may not be a bad idea, but if your cylinders are holding oil, I would be inclined to leave well enough alone as it is very easy to open Pandora's box and spend quite a few dollars and time on resealing. There will be a piston on the opposite end of the rod that will probably be threaded on anyway. These machines were built "the right way", as in threaded components, mechanical joints and traditional workmanship. Other than lack of greasing leading to premature wear, the old girl looks in reasonable condition and should be a reasonably cheap machine to operate. Does the hour meter still work? If so, how many hours has she got on her?
9th Nov 2015, 08:18 PM #7
Yeah I have posted the old girl up on few forums. I know stuff all about this tractor, so hopefully a bit of "show and tell" will help me out. Already have found out a few facts about her I didnt know.
Then there's the saying, "no fotos and it didnt happen!!" And we all like fotos.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
9th Nov 2015, 08:46 PM #8
Hours: Havent looked to see if its even connected, too busy playing sandpits Should pay more attention to see if the numbers scroll , but has probably gone around the clock anyhow.
Certainally has done its fair share of work. Clutch doesnt seem to have much play left. middle (2nd) gear wont stay in gear.
Starts without fuss. Expected a few niggles that come with old equipment.
Hydraulics as expected are a bit slow, but everything seems to work in this dept.
In all a low tech unit, just the way I like em.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
12th Nov 2015, 12:50 AM #9Most Valued Member
- Sep 2010
- Lebrina
- 1,916
They seem to be a well respected unit, (the 154 tractor), albeit one that was introduced at a strange time. It seems that Leyland had the opposite issue with the 154 to the one faced by the infamous P76 car. One was a small tractor being marketed when everyone else was going big and the other was a big car, released when thew rest of the market was downsizing. Having said that, they had a fairly long model run and today are recognised in their home country as a smart choice for small holdings.
Parts may be a little difficult to come by as neither Bareco, Sparex or Bepco seem to list your model, but there may be other aftermarket suppliers that cater for your 154. A lot of lighting, electrical and even mechanical parts will be pretty generic anyway.
Low tech is good from a maintenance/repair perspective.
12th Nov 2015, 02:39 PM #10
The Leyland Tractor (UK) forum is looking promising in the parts dept. Of course one doesn't want to get stuff from that far abroad unless really need to .
From casual glance elec all looks to be the infamous Lucas. Diesel mech that visited here (we get all kinds of folk here at the shop) on other matters seemed to think I should be ok with many repair items.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
12th Nov 2015, 07:31 PM #11Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Ah yes Lucas, Lord of Darkness. Having grown up on Land Rovers and Fergusons, he has touched me on several occasions. Having said that, once he was all we had.
A Bosch alternator will fit nicely in place of the Lucas alternator, (surely they don't still run a Lucas generator do they?), if required and the starters seem to be pretty trouble free. Switch gear can probably be substituted with either Massey Ferguson or later model Leyland parts. That's the beauty of the old girls, you can mix and match, plus not a great deal changed between makes and models. What you can't buy, you can make.
12th Nov 2015, 10:38 PM #12Ah yes Lucas, Lord of Darkness. Having grown up on Land Rovers and Fergusons, he has touched me on several occasions. A Bosch alternator will fit nicely in place of the Lucas alternator, (surely they don't still run a Lucas generator do they?), if required and the starters seem to be pretty trouble free. Switch gear can probably be substituted with either Massey Ferguson or later model Leyland parts. That's the beauty of the old girls, you can mix and match, plus not a great deal changed between makes and models. What you can't buy, you can make.
Helpful folks from Leyland Forum UK seem to think mine is about a 78 vintage. So one would think alternator. I know she starts easily, once you give it about 20 odd sec on the glows.
So far so good.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
13th Nov 2015, 07:13 PM #13Most Valued Member
- Sep 2010
- Lebrina
- 1,916
15th Nov 2015, 05:17 PM #14
Looks to me like glow plugs.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
15th Nov 2015, 09:55 PM #15Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Hydraulic oil foaming in a pressbrake
By pcx in forum METALWORK GENERALReplies: 20Last Post: 19th Jun 2014, 08:07 AM -
Hydraulic ram
By GSRocket in forum METALWORK GENERALReplies: 8Last Post: 6th Oct 2012, 10:19 AM -
Hydraulic Press Jigs
By Oldneweng in forum METALWORK GENERALReplies: 4Last Post: 1st Jul 2012, 09:25 PM -
Hydraulic pipe bender
By Softbreeze in forum METALWORK GENERALReplies: 4Last Post: 24th Jul 2009, 07:03 PM -
Hydraulic Log Splitter
By Geoff Dean in forum METALWORK GENERALReplies: 8Last Post: 15th Apr 2008, 12:01 AM
