Results 1 to 15 of 15
Thread: Plasma cutter
7th Aug 2015, 07:36 PM #1Senior Member
- Apr 2013
- Bunbury WA
- 98
Plasma cutter
I am thinking of buying a plasma cutter, a quick look at BOC and they have one for $900+ , on Ebay there are combination tig/plasma for around $400, Rossi brand.
Does anyone have any experience with this brand or some other similar? I want it mainly for thin sheet, I have a gas axe for heavier plate but it generally struggles with the thin stuff.
TIG with high frequency start is attractive but I can live without it.
Any advice appreciated.
clive
8th Aug 2015, 12:24 PM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I'm not a big fan of BOC gear as the price is far higher than the quality of the product. $900 for a machine to handle thin sheet is getting way up there as I paid $750 for my 50A plasma and I know that others on this forum have bough off ebay for less than $400 I think and they were quite happy with their machines.
My plasma, from Magnum Welders has happily handled thicknesses up to 12mm for me and I have seen a piece of 16mm cut with the same machine. You will be better off with oxy above 6mm though in my opinion.
BOC are just another reseller of chinese gear for the most part and the big name means little.
8th Aug 2015, 12:46 PM #3
I've got two WeldSmart (they are in WA) plasma cutters, a 50 and 60 amp models. The 50 amp has a pilot arc which is handy and cost around the $400 mark (maybe $450, can't quite remember).
The 50 has done a heap of work and has performed flawlessly. The 60 doesn't have a pilot arc and I don't tend to use it much.Cheers.
Vernon.
8th Aug 2015, 01:47 PM #4Senior Member
- Apr 2013
- Bunbury WA
- 98
Thanks for the info. The reason I was looking at BOC is I was thinking about after sales service if anything died within warranty. I have bought several welders from them and the last was a Chinese Smootharc, it really performs well but doesn't get much exercise as I tend to go to my flux core first, mainly laziness on myself part.
22nd Oct 2015, 10:03 PM #5Senior Member
- Apr 2013
- Bunbury WA
- 98
I finally took the plunge based on reviews and comments on this forum and got a combination plasma/tig machine from Tolkin Tools. The guy there was really good to deal with so I'm looking forward to next weeks delivery. Thanks
22nd Oct 2015, 11:25 PM #6Most Valued Member
- Sep 2010
- Lebrina
- 1,915
22nd Oct 2015, 11:38 PM #7Senior Member
- Apr 2013
- Bunbury WA
- 98
My current tigs are both scratch start which is a bit of a pain, trouble was Before I retired we had HF and was spoilt.
30th Oct 2015, 08:19 PM #8Senior Member
- Apr 2013
- Bunbury WA
- 98
My Allusync 200 arrived yesterday, with great restraint for me I actually read the manual before I even touched the machine. I started putting it together this arvo but needed an air fitting and decided rather than go buy one I would machine one so I'm going to cobble it up out of two in the morning. I'll try it out and post how it goes.
31st Oct 2015, 06:10 PM #9Senior Member
- Apr 2013
- Bunbury WA
- 98
Well I fired it up this afternoon, I'm making a plasma pattern cutting jig and tigged the parts together. Very smooth, it upsloped beautifully but I had set the downslope to half way which took a bit longer than I would like but no complaints at all. I'll set up the plasma on Monday, in fairness to the neighbours. If it performs as well as the tig it's going to be a worthwhile purchase.
31st Oct 2015, 06:23 PM #10Golden Member
- Feb 2010
- Ballina, NSW
- 900
Pictures or it didn't happen
I've got the original alusync model and it's been a great machine for tig, stick and plasma. My only complaint is that I hate swapping around the leads for the different operations as I tend to do a bit of each in every workshop session. Make sure you set up a dry air source for the plasma, otherwise you'll burn through tips pretty quickly.
- Mick
31st Oct 2015, 07:24 PM #11Senior Member
- Apr 2013
- Bunbury WA
- 98
Here ya go Mick, I was going to use the plasma but my wfe reckons I'm too noisy so I'll leave it till Monday when everyones at work
31st Oct 2015, 10:31 PM #12Golden Member
- Feb 2010
- Ballina, NSW
- 900
Evidence noted.
1st Nov 2015, 10:11 PM #13Senior Member
- Apr 2013
- Bunbury WA
- 98
Made this circle cutter for the plasma handpiece today. I machined it to fit with a couple of thou clearance, cut a split on one side. This was tapped 1/4 unc and clamps around the handpiece really easily. The bar is 1/4 squ, drilled it 1/4 then filed the squ. Got a nice sliding fit, next I'll tap it 3/16 for a locking grub screw.
2nd Nov 2015, 09:22 PM #14Golden Member
- Feb 2010
- Ballina, NSW
- 900
2nd Nov 2015, 11:43 PM #15Senior Member
- Apr 2013
- Bunbury WA
- 98
The grub screw worked just fine, I have 8 circles to cut out and it's good to be able to put the torch down and pick it up in the morning and nothing has shifted, makes life easier.
Cut-40 Plasma cutter
By .RC. in forum WELDINGReplies: 92Last Post: 29th Nov 2015, 10:25 PM -
Plasma cutter
By Marc in forum METALWORK GENERALReplies: 0Last Post: 28th Mar 2012, 08:37 PM -
CNC Plasma Cutter.
By the_duke in forum METALWORK GENERALReplies: 2Last Post: 12th Jan 2010, 01:32 AM -
Plasma Cutter add-on
By captain_caveman in forum WELDINGReplies: 4Last Post: 20th Nov 2009, 04:30 PM -
Plasma cutter
By Ironstine in forum WELDINGReplies: 2Last Post: 23rd Feb 2008, 01:25 AM
