Results 1 to 11 of 11
14th Apr 2015, 08:52 PM #1Novice
- Nov 2010
- 13
Tig welding - what else do I need ?
Howdy
I want to start playing around with tig welding and am wondering what else I need to get.
I've got a cigweld 170 inverter welder and a tub full of bits that I bought of ebay.
I've also got a tank of speed shield for the mig but am pretty sure this is no good for tig ? Need argon ?
Anyway. Have a squizz at the pics and let me know what you see. Also what is the gadget with the dial on it ?
Matt
15th Apr 2015, 07:47 AM #2Philomath in training
- 6,562
15th Apr 2015, 09:03 AM #3
Yes, you will need pure argon, not the speed shield, gas.
The thing with the dial could also be a back-purge hose, is the black lead it's on an electrical cable or a hose?
15th Apr 2015, 11:27 PM #4
You are missing a regulator and a flow meter for the gas.
Cheers, Joe
18th Apr 2015, 02:54 PM #5Diamond Member
- Aug 2006
- 1,106
19th Apr 2015, 01:12 AM #6
An auto face shield that is adjustable to TIG settings
Tungesten tips suitable for what you wish to weld suggest you go to a Cig store and talk to the staff, take your pics
Gloves and good piece of copper plate to weld onAshore
The trouble with life is there's no background music.
19th Apr 2015, 09:52 PM #7
20th Apr 2015, 09:11 AM #8
No idea why Ashore suggested a copper plate but, for mine, I have a 2' x 1' sheet of 1/4" copper plate fixed to a heavy steel frame that I use when welding small stuff. The return lead is clamped to the plate and stuff to be welded just needs to sit on the plate for good electrical contact - it's a lot easier than trying to clamp the lead to the small parts. Mind you I set that up over 30 years ago when copper was considerably cheaper, I haven't priced copper sheet for some time!
I don't use it as much these days as I now have a Stronghand table but it is still very useful when working off-site and gets used a lot in those circumstances.
20th Apr 2015, 10:38 AM #9Novice
- Nov 2010
- 13
Awesome. Thanks guys. Will head to the store this week. I'll price some copper plate too.
I have a regulator for my mig so that's all good
20th Apr 2015, 12:16 PM #10Golden Member
- Sep 2008
- N/A
- 535
You're probably going to need a ground lead/clamp too.
23rd Apr 2015, 08:33 PM #11Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
i have the same tig torch as in your pic (middle) scratch tig welding is a whole new ball game over HF tig welding where u push the trigger and the arc starts, i found with my tig when i initiate the arc by scratching well i dont get far the initial contact sticks the electrode to the piece so i found holding the torch in my welding hand and using my other hand to help lift the torch once initial contact is made
i hold my torch in my left hand than i hold the filler rod with my right thumb and first finger, i use my second third and fourth fingers to help lift the torch off the work piece just enough to keep the arc than i weld away
tig welding is very addictive its my choice of welding
C02 for Mag Welding
By toyota254 in forum WELDINGReplies: 20Last Post: 13th Jun 2012, 04:56 PM -
new to welding.
By Bluegum in forum WELDINGReplies: 8Last Post: 24th Oct 2006, 09:22 PM -
welding tip
By mako in forum WELDINGReplies: 4Last Post: 7th Jul 2006, 04:59 PM
