Results 1 to 8 of 8
Thread: braze welding copper
31st Jan 2015, 06:41 AM #1New Member
- Aug 2007
- 3
Hi Folks
Any tips on braze welding copper wire please, I am trying to do some wire art.
What brazing rod should I use?
31st Jan 2015, 09:24 AM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,915
You have a few options available to you. Phos Copper, which doesn't require a flux. Tobin Bronze, or Comcoat T in it's pre flux coated form, Nickel Bronze, or Comcoat N if pre coated.
Have you considered soft soldering or even silver soldering the joints? A 2 or 5% silver brazing alloy should work quite nicely I would think.
This may be a lot easier to achieve than full on brazing with the sort of thickness wires I am envisaging you to be using.
31st Jan 2015, 10:38 AM #3
Soft solder will be soooo much easier!
5th Feb 2015, 06:42 AM #4New Member
- Aug 2007
- 3
Thank you very much for the feedback. Appears, soft solder / silver solder will be the best.
I notice a couple of youtube videos where the person uses a product called RG45. This is a copper sheaf mild steel rod. Any thoughts.
Keeping in mind he uses this stuff instead of copper to build his models.
cheers
Dave
5th Feb 2015, 09:50 AM #5
RG45 are gas welding rods. A lot stiffer than straight copper wire. Generally only available in approx 600mm lengths (or around that size, I'm estimating). Available in a few different diameters (1.6mm, 2.4mm, 3.2mm, etc).
Not sure how it would soft solder (might be ok), but I expect it could be silver soldered and/or brazed.Cheers.
Vernon.
20th Feb 2015, 06:25 PM #6
The other option for steel/aluminium wire would be TIG welding.
2nd Mar 2015, 08:48 PM #7New Member
- Aug 2007
- 3
Ok, I have been able to source some R45 copper sheathed gas welding filler rods. I believe these will be good to use for making figures.
Good thing is I can silver solder them or even spot weld (tac) using the MIG.
Will have to play around and see which gives best results.
cheers.
3rd Mar 2015, 07:03 AM #8
I'm not sure if it matters (from the point of view of corrosion), but something to think about - if tack weld you will lose the copper coating at the joint. Silver soldering will actually protect the joint and prevent corrosion (if you clean the flux away properly).
Cheers.
Vernon.
Cast Iron - Braze or Silver Solder?
By Buncha in forum WELDINGReplies: 8Last Post: 23rd Feb 2009, 10:04 AM -
Copper to copper
By slepax in forum WELDINGReplies: 4Last Post: 19th Oct 2008, 04:10 PM -
welding copper
By Harry II in forum WELDINGReplies: 9Last Post: 6th Sep 2008, 08:45 PM -
braze Tungsten tip
By jackaroo in forum METALWORK GENERALReplies: 7Last Post: 10th Oct 2007, 09:26 AM -
Welding Copper Tube
By Edd in forum WELDINGReplies: 24Last Post: 11th Oct 2006, 03:45 PM
