Results 31 to 37 of 37
31st Jan 2015, 09:03 AM #31Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Boiling in water couldn't hurt, particularly if a bit of detergent or non flammable degreaser were added. Naturally, you would want to do this outside, rather than in the good lady's kitchen.
31st Jan 2015, 09:22 AM #32Senior Member
- Jan 2015
- 211
Think ill try this, probably sand blast them too cause im going to repaint anyway. Theses other parts are more critical to get it right first time. Thanka for your help Karl.
31st Jan 2015, 12:55 PM #33Most Valued Member
- Sep 2010
- Lebrina
- 1,916
If you are repainting and you know that they are steel/cast iron with no aluminium components, then hot water and caustic soda will clean them up as clean as you could want along with removing the paint. A good rinse with water afterwards and you are good to go.
Definitely don't do this in the kitchen and wear gloves and face protection as a minimum. Don't pour it on the lawn to get rid of it either as your lawn will be an ex-lawn wherever it hits.
Caustic will dissolve skin in high enough concentrations. You can buy it in supermarkets though
6th Feb 2015, 04:54 AM #34Senior Member
- Jan 2015
- 211
Second repair went beautifuly. No undercut and wetted in nicly.
For thoses interested. Ac, 100amps, 80%en and 150hzs.
7th Feb 2015, 12:24 PM #35Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Well done, glad it all worked out.
I wonder if the electrodes would have worked for you on the last repair as you seem to have got the cleaning issue sorted.
Anyway, good job, you did what you had to do to get the job done and that's what it's all about
7th Feb 2015, 01:14 PM #36Senior Member
- Jan 2015
- 211
I did wondar too, got them installed on the lathe and its all sweet now.
9th Aug 2019, 10:02 PM #37Senior Member
- Feb 2009
- jilliby nsw
- 111
Cast Iron Repair
By Scott in forum WELDINGReplies: 6Last Post: 18th Sep 2013, 01:42 PM -
Bronze welding cast iron
By morrisman in forum METALWORK GENERALReplies: 2Last Post: 24th Mar 2013, 07:06 AM -
Cast iron pot repair
By lordnelson in forum METALWORK GENERALReplies: 19Last Post: 12th Oct 2011, 08:36 PM -
Cast Iron Weld Repair
By Woodlee in forum WELDINGReplies: 4Last Post: 22nd Jun 2008, 10:13 PM -
Repair of Broken Cast Iron
By Grahame Collins in forum METALWORK GENERALReplies: 0Last Post: 11th Feb 2006, 11:35 PM
