Results 1 to 4 of 4
Thread: Inverter Welder Arc Stength
10th Jan 2015, 07:07 AM #1New Member
- Mar 2007
- Central Coast NSW
- 2
I am a novice welder and have previously been using an old arc welder to join metal. I won't call it welding as what I do certainly doesn't look like welding
I have now been given a DC Inverter welder but it has two settings on the front. Arc Force in Amps and Current in Amps. I understand the Current setting but how does the Arc Force relate to welding??
Any help appreciated.
Thanks,
Jason
10th Jan 2015, 07:44 AM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Put basically, it changes the arc characteristics to produce either a wide but shallow bead or a narrower, deeper penetrating bead. Depending on your welder it may be infinitely adjustable via a pot or more commonly there will be two basic settings. You can fine tune the arc for sheet metal and thin rhs, out of position, pipe root runs or for stainless and low hydrogen electrodes.
What brand and model of welder is it?
10th Jan 2015, 07:44 PM #3Diamond Member
- Jun 2010
- Canberra
- 1,322
To give a bit more of a technical explanation, stick welders are constant current (CC) machines (MIG is constant voltage). So you set the amps you want for the particular electrode, material and welding position and away you go.
If arc force is set to zero, the constant current thing is absolute - you set 90A, that's all you'll get, even if you get a bit too close and stick the electrode. For that reason, you always want a bit of arc force, as it'll help to prevent the rod sticking by allowing the current to rise a *bit* above the 90A setting if needed.
If you set the arc force dial to max, it'll allow the amps to go *way* above what you set on the dial. So with the dial on 90A, as you shorten the arc and get very close to the material or touch it, it'll allow the current to shoot well above 90A. That helps to prevent sticking, and gets more penetration as you shorten the arc.
So if you're welding thin material and fear blowing holes, a low arc force helps to limit blowthrough, with the downside of electrode sticking if your technique isn't 100% That said, if the amps dial is set too high, you'll be blowing holes no matter what the arc force is.
If you're welding thicker material, or into a tight joint where you really want a fierce arc to penetrate, you want plenty of arc force.
16th Jan 2015, 01:26 PM #4New Member
- Mar 2007
- Central Coast NSW
- 2
Thanks for your input. I will go and do some testing now. I a trying to weld 30mm shs so the wall thickness is pretty thin
'New' inverter welder
By jhovel in forum WELDINGReplies: 2Last Post: 4th Mar 2013, 04:34 PM -
Inverter mig welder
By dubman in forum WELDINGReplies: 6Last Post: 30th Oct 2011, 09:41 PM -
Inverter welder help.
By BLKWDW in forum WELDINGReplies: 0Last Post: 18th Feb 2011, 10:21 PM -
Inverter Welder
By Outbackrr in forum WELDINGReplies: 9Last Post: 17th Jun 2008, 10:40 PM -
Inverter Welder
By Just George in forum WELDINGReplies: 10Last Post: 18th Jan 2006, 09:00 AM
