Results 1 to 15 of 19
30th Nov 2014, 06:10 PM #1Golden Member
- Feb 2010
- Ballina, NSW
- 900
Shopping list to convert to CO2 MIG (well GMAW really)
OK fellas, I'm keen to make the step to 100% CO2 for my MIG welding after a couple of years on Ar/CO2/O2 mix. My current usage is just over one 'G' cylinder a year. I know there's a few posts floating around on this, but I'd appreciate a recap and some contemporary advice.
- What's the best deal on a CO2 cylinder? This one http://www.ebay.com.au/itm/Australia...item1c49e62d8f at $199 for a 6Kg version looks OK. Any better ones?
- What about refills/cylinder swaps - what's the best deal/system? I'm in Ballina northern NSW. Swap/postage pricing?
- I have a standard Argon/CO2 regulator, but I'm guessing the connector thread/size is different - where to get an adapter? online source?
- Mick
30th Nov 2014, 06:20 PM #2Senior Member
- May 2007
- South Australia
- 100
If your using a G per year 6KG home brew will last you 5 minutes
Surely G cylinders would justify rental?
30th Nov 2014, 07:44 PM #3Diamond Member
- Jun 2010
- Canberra
- 1,322
You get *far* more gas for the volume with CO2 compared to argon mixes as the CO2 converts to its liquid state whereas the argon mixes remain a gas. Someone did the calc in another thread somewhere.
Gasweld stock CO2 regs - I think they were around $85 last time I checked. Haven't seen them anywhere else.
The other addition I made was an adapter to go from the Jamec female on the end of my CO2 reg hose to Nitto female so I can connect my tyre inflator to it. You can then take a PET bottle, fit a tyre valve stem to the cap and carbonate pretty much any liquid (chill the liquid, keep the pressure down, and shake between doses of gas).
Try that with your fancy Argoshield.
1st Dec 2014, 05:05 PM #4Golden Member
- Feb 2010
- Ballina, NSW
- 900
Roughly speaking, a 'G' gives less than 20 hours welding. My use is sporadic, so I might use half a cylinder in 1 week, and the other half in the last 6 months of the year. Rent costs me a bit less than $200/year. I've looked at E size etc. before, but it still worked out better economically to have G size although I'd much rather have a more portable shielding supply - hence my interest in CO2.
I think that was me. By my calcs 6Kg CO2 = about 3000 litres = 5 hours welding roughly.
I've got a reg, it even has CO2 graduations, I just need to find where to get a thread adapter.
I can't think of a worthwhile beverage that doesn't already have bubbles
1st Dec 2014, 05:36 PM #5
Hi Mick,
I use the Q size for CO2. It typically lasts me 10 to 15 days of welding. No idea what my weld-on duty cycle is. My supplier calls it a 40 lb cylinder but I can feel that it weighs a lot more after filling. You can use an argon regulator but you need a CGA 680 to 320 adapter like this http://www.ebay.com/itm/Western-Styl...item4adcba36b6. Be sure to get some extra seals too http://www.ebay.com/itm/Co2-O-Ring-W...item3384d1147c. They have a tendency to get lost or damaged when you need them. Shop around for better prices, I just used these links as examples so you could see some pictures.
Rob
1st Dec 2014, 07:31 PM #6Golden Member
- Feb 2010
- Ballina, NSW
- 900
Thanks Rob, I couldn't find much about this size except this pic from BOC, but if it's a 40lb'er then I guess it stores about that weight of CO2. Do you rent or own the cylinder?
That's exactly the sort of info I'm after.
I'd love comments from anyone who has bought an ebay cylinder
2nd Dec 2014, 12:58 AM #7
Mick,
I bought my cylinder. Fully charged with gas it was about $190 and refills are $45, rentals typically are in the range of $10-$15 per month here. This one is supposedly sold by weight but I can tell it has been loaded with significantly more than 40 lbs when they recharge it. In this area refills of gasses don't scale directly to the size of the cylinder. For instance I have one of the small oxy-acetylene rigs for HVAC type work and refills of the acetylene run about $30. The 75 C.F. acetylene tank on my bigger oxy rig runs about $65 to refill and it holds much more gas.
If you can get the polyethylene seals. The Teflon seals are more expensive and they deform more easily making re-use more difficult. Either way you only need to tighten them about 1/4 turn past hand-tight to form an effective seal, any more and you can get leaks.
I don't know what your local prices are like but for me buying on eBay would have been more expensive than buying the cylinder from the welding supply.
If you go with the CGA adapter make sure that you get one of the right sex, i.e. female on both ends. You don't want the one made for attachment of a CO2 regulator to an argon tank. When you use it tighten the adapter to the regulator first and then attach the combined regulator-adapter to the tank. If you attach the adapter to the tank and then attach the argon regulator to the adapter you run the risk of deforming the sealing gasket and creating a leak. Test the fit-up by putting a little water containing some dishwashing detergent on the joint and look for bubbles after you're done. If you want a commercial bubble leak test fluid they sell one for picking up gas leaks in the plumbing departments of the larger home improvement supply stores. Snoop is another option but ridiculously expensive.
Rob
3rd Dec 2014, 08:12 AM #8Golden Member
- Feb 2010
- Ballina, NSW
- 900
Thanks Rob, good info there.
- Mick
3rd Dec 2014, 01:58 PM #9
Surely if you where to use a standard industral gass CO2 bottle standard RH thred pol regs would fit.
And unless you where pulling volume, there would be no necessity for a specilaised CO2 reg.
and in Balaina, you should not be too far away from the speedgas agent.
People are made of meat.
3rd Dec 2014, 05:29 PM #10Diamond Member
- Jun 2010
- Canberra
- 1,322
3rd Dec 2014, 05:33 PM #11Senior Member
- May 2007
- South Australia
- 100
Worth checking out, you will get a bigger bottle then.
3rd Dec 2014, 05:43 PM #12Golden Member
- Feb 2010
- Ballina, NSW
- 900
3rd Dec 2014, 05:46 PM #13Golden Member
- Feb 2010
- Ballina, NSW
- 900
3rd Dec 2014, 06:26 PM #14
Consider that I believe speed gas supply some of the home brew shops, small post mix users and low volume liquer outlets, it will be worth checking out.
As far as renting for your argon.....hell man...get a price from speedgas....unless you are a volume user and on a deal.....you will be ahead in the second year.
3rd Dec 2014, 08:09 PM #15Golden Member
- Feb 2010
- Ballina, NSW
- 900
Well - I pay through the nose for gas, so I'm pretty sure I'm not on a deal. I don't use much in the scheme of things.
I'll be very interested in speedgas' response. No local agent that I know of, closest listed is a bit over 1hr drive away. I used to have a BOC account, now I go through a coregas agent.
