Results 1 to 7 of 7
Thread: what welder
    Sep 2014
    australia
    9
    Default what welder
    Hi Guys im interested in makeing a few things out of aluminium checker plate in 2.5 mm thick, my question is what sort of welder u would recomend MIG or Tig, i have some experiance with mig on steel but none with tig and what make would u recomend at about the $1500 mark cheers
    Apr 2008
    269
    Default Welder
    Don't know where you live in oz bloke, but some forum members on here swear by TokenTools, check out their website, you will need a Tig that does AC/DC for alloy. Think TokenTools are in Wagga, or near abouts.
    DD
    May 2013
    Australia
    4
    Tig is the go in that thickness range. When looking for a machine it must be acdc
    Sep 2010
    Lebrina
    1,914
    Definitely TIG if you are restricted to only one welder.
    $1500 will definitely get you into something very workable along with a selection of consumables and an auto shield.
    In case you haven't already considered it, you will be needing a 15A power point to run your new toy.
    Sep 2014
    australia
    9
    thanks guys tig it is will let u know how i go
    Aug 2009
    Sydney, NSW, Australia
    1,841
    i would go with a MIG spool gun 2.5mm will be a piece of cake to weld, i welded 1.6mm with a cheap ebay MIG/spool gun on youtube done it very easy but the slightest gap between the two pieces being welded will blow a hole
    i bought the LOTOS mig from ebay for $450 as a buy now price brand new came with a regulator and spool gun (compatible with lincoln) the seller list about 2 LOTOS MIG/spool gun welders a month on ebay
    ive just uploaded 2 pictures of my 1.6mm spool gun welds and im only very basic welder just learning to weld
    i spent over $600 on a TIG machine and it was nothing but a pain in the ass to use i never got the hang of it eventually selling it and loosing out on money i bought this welder
    here is a video doing that 1.6mm aluminum weld so u can see it actually being welded
    https://www.youtube.com/watch?v=KJnM...lOHw65q9PUliCw
    Dec 2014
    NA
    2
    Default You can select one of the following machines:
  1. QUEENSLAND Cig welder transarc tradesman HD (stick/arc welder) 3phase
    By dkaoffroad in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 8th Jun 2013, 10:45 AM
  2. Bob the Welder
    By Charleville in forum WELDING
    Last Post: 1st Jul 2008, 07:33 AM
  3. What do you think of this welder?
    By jackaroo in forum METALWORK GENERAL
    Last Post: 7th Jul 2007, 01:48 AM
