Results 1 to 13 of 13
Thread: Shades in Auto darkening helmet.
14th Aug 2014, 10:25 PM #1Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
I was welding up an old sink for a motor cover recently and had the Tig set at 35 amps and had trouble seeing the arc with the helmet set on shade 9. The helmet is a Metalmaster Elite 9860 Digital from Tokentools and it has 3 ranges, Grind, Cut and Weld. (Sorry cant post a link from this tablet) Weld is from 13 to 9 then Cut is 8 to 5, so I set it to shade 8 and was able to see the weld pool to do the job. Following on from previous threads, is it OK to weld with reduced current on the Cut mode? I did not appear to suffer white spot or get gritty eyes.
Thanks,
Rgds,
Crocy.
14th Aug 2014, 10:58 PM #2Senior Member
- Jul 2009
- 133
This is the helmet the above post referres to
http://weldingstore.tokentools.com.au/welding-safety-equipment/welding-helmets-automatic-welding-shields-masks-auto-darkening/multi-process-welding-helmets/auto-darkening-welding-helmet-plasma-cut-weld-grind-metalmaster-digital-purple.html
Looking at one of these myself atm... looking forward to the feedback you get
15th Aug 2014, 07:49 AM #3Philomath in training
From previous discussions, the helmet protects you from the 'nasty' bits of radiation regardless of the shade (Provided you have safety glasses on - see other posts). All the shade selection is doing is making it comfortable for your eyes.
15th Aug 2014, 08:43 PM #4Member
- May 2008
- 79
Straight From The Horses Mouth
Hi Crocy,
As Michael and others have stated the UV and IR protection is built into the cartridge so the level of tint of the LCD is adjusted to simply suit the operator's comfort level. There is no danger in using it out of mode and safety glasses are a must.
Pete (Tokentools)
17th Aug 2014, 07:59 PM #5Senior Member
- Jun 2005
- 226
DocBug, I am very happy with the helmet, love the cut mode for when I use the plasma cutter.
Thanks for that Michael, I went back and reread the other thread and it is clear to me now.
Hi Pete thanks for the reply as well. I don't suppose you are having a holiday in North Queensland any time soon, I still can't figure the new Alupulse 200 out, hoping Grahame is going to get his shed finished soon and then I will take it down to him to get some lessons.
Thanks again guys,
Rgds,
Crocy.Last edited by Old Croc; 17th Aug 2014 at 08:01 PM. Reason: autospelling mistake
17th Aug 2014, 08:48 PM #6Senior Member
- Jul 2009
- 133
Hi Crocky,
I actually ordered one on Friday, hopefully have it here tomorrow
Alan
17th Aug 2014, 09:23 PM #7Member
- May 2008
- 79
Stuck on a computer on a Sunday night ...... I'd love a holiday in NQ, you offering?
Regarding settings, I assume it is AC that you are having troubles with and I would like to advise as follows. Use around 30 amps for each millimetre of material thickness. Make sure your tig torch is in the negative and job clamp is positive. Set your AC balance to 40% (about 10 O'Clock position) and AC frequency to 150Hz (about 12 O'Clock Position). Turn off all yellow knobs (pulse section), turn off blue knobs (up/down slope), turn off arc force(used for MMA welding). Stick your tungsten 2 x It's diameter past the ceramic nozzle. Set gas flow to 7 litres minimum and allow 1 litre per 15 amps after 70 amps.
Keep your tungsten 2-3mm off the job when welding and ensure you are welding with pure argon.
You can also reach me on 02 8014 1005 also if you need help.
Pete
19th Aug 2014, 11:22 AM #8Novice
- Feb 2009
- Forest Range, SA
- 22
19th Aug 2014, 11:44 AM #9Senior Member
- Jul 2009
- 133
Sometimes you get hot metal bits bouncing up behind the helmet. It's just a second barrier that affords a little extra protection.
19th Aug 2014, 01:18 PM #10
19th Aug 2014, 08:50 PM #11Senior Member
- Jun 2005
- 226
Good to hear. Can't wait to see if your PV arrangement from the other thread works and if your system interferes with any of your gear. I am going to give Pete's suggestions a go and let you know. The next race is the 20th of September, so chase your leckie up.
Rgds,
Crocy.
29th Aug 2014, 08:40 PM #12Senior Member
- Jun 2005
- 226
Oh this is embarrising to admit in this forum, swapped the leads over and it welds real good now. Still can't work out why as on AC you don't have polarity, could understand if I was using DC.
Thanks again Pete, the phone call was cheaper than flying you up here,
Rgds,
Crocy.
1st Sep 2014, 01:30 PM #13Golden Member
- Sep 2008
- N/A
- 535
Some do. Mine does. It's got fixed terminals for electrode and ground, but you can switch start polarity of the electrode terminal in the advanced menu options. Changes cleaning action at the start or something? I'm not sure but vaguely remember reading some internet discussion of why anyone would do this.
Auto darkening Helmet
By Marc in forum WELDINGReplies: 12Last Post: 31st Jul 2014, 10:29 AM -
Cheap Cigweld auto darkening helmet is a "throw away" type - take note.
By beefy in forum WELDINGReplies: 10Last Post: 15th Dec 2012, 08:20 PM -
Auto darkening helmet mods
By .RC. in forum WELDINGReplies: 1Last Post: 3rd Apr 2010, 12:52 PM -
CIGWELD WeldSkill® Auto Darkening Helmet
By DJ’s Timber in forum WELDINGReplies: 12Last Post: 2nd Mar 2009, 08:48 PM
