Results 1 to 7 of 7
    Apr 2013
    adelaide
    293
    Default Steel plate for welding table
    My welding table has a stainless top; however, it is too small (600mm x 600mm) so I intend on making a larger table. Any ideas on where to get (cheap) 12mm + scrap plate in Adelaide, around a metre square, give or take? I intend on bracing the underneath of the plate to prevent distortion as on my current S/S plate so 12 mm plate shouldn't be a problem.
    Sep 2010
    Lebrina
    1,910
    Gee, 1000 X 1000 X 12 plate couldn't really be called scrap.
    I reckon you may nearly need to approach a steel retailer or fabricator and get a piece ripped off a plate, possibly even a 500 X 1800 or 500 X 2400 piece that you then turn into a 900 X 1000 or 1000 X 1200 piece.
    7,182
    Quote Originally Posted by Karl Robbers View Post
    Since I retired last year I have done a scrap steel "milk run" around a few salvage yards and steel suppliers about every month. The biggest piece of scrap 12mm plate I have found has been some circular pates about 450 mm in diameter. I did find a 2400 x 1200 piece of 3/4" thick plate that was advertised on gumtree for $150 and thought that would make a great bench top until I found out it was used as construction road way plate so it was buckled well beyond that sort of use.
    Jul 2003
    Sydney
    493
    Wow 3/4" ! How did you plan to transport that monster? And then make a bench out of it?
    Civilized man is the only animal clever enough to manufacture its own food,
    Barry Groves
    Apr 2013
    adelaide
    293
    Default Sims.
    I used to get all my steel from Sims in Spearwood before I moved east in 2006. They had loads of second hand steel and plate of pretty well any size you wanted. Good prices also.
    7,182
    Quote Originally Posted by Marc View Post
    The plan was to borrow a tree lopper mates Hiab and bring the plate back to his yard and break it up with an oxy.
    I only wanted a piece that was 600 x 900 (80kg) as the top for my bench and I was going to leave the remainder at the tree loppers.
    Jul 2003
    Sydney
    493
    I made my welding table with two parallel flanges C channel 380x100x900, well over 100K
    I bolted them together with 19mm bolts and tack weld them from below and to the steel frame. Way over engineered but at the time ... 25 years ago, I worked with BHP in their wiremill and scrap steel was plentiful...
    Jeee, 25 years ago ... remind me of that line at the end of the expendables when Silvester Stllone gets his Grumman Albatross back. -"That belongs in a museum" ... and the reply: -We all do!
    ha ha
    Barry Groves
  1. Advice on welding thin steel plate
    By Sterob in forum WELDING
    Last Post: 31st Jul 2012, 06:57 PM
  2. Flattening a steel plate
    By WelderMick in forum METALWORK GENERAL
    Last Post: 2nd Jun 2010, 10:21 PM
  3. Replies: 1
    Last Post: 24th Oct 2008, 09:29 PM
