Results 1 to 6 of 6
8th May 2014, 10:53 PM #1Member
- Feb 2014
- Newcastle NSW
- 78
Very first TIG welds. please advise
Ive started the journey to learn to TIG weld tonight and im really struggling. Any help and advice is most welcome. im running 2.4mm tungsten, pure argon onto 5mm plate with 2.4mm filler rod. reg is set at 17 lpm what do you guys recommend? the metal i used to weld on was not the cleanest so i understand the dirty look of the welds. The cone is a #7. please advise CAM00099.jpgCAM00100.jpgCAM00101.jpg
8th May 2014, 11:06 PM #2
At first glance the welds look cold with little sign of wetting to the base metal. What amperage are you running?
17 lpm is too much, you should be starting around 6 or 7 lpm. Too much gas is as bad as too little as it causes eddies which drag the outside air into the weld area.
With TIG welding cleanliness is next to godliness, you must clean the base metal to have any chance of making a decent weld, use a flap disk in a grinder to get the base metal bright and shiny and try again.
Presumably you sharpened the tungsten (taper length around 2 to 3 times the diameter of the tungsten). You need to keep the arc distance as small as possible, preferably about the same as the electrode diameter.
Have another go with 7 lpm gas flow, short arc distance and clean base metal and lets see what they look like - we need to know the settings you used for the welds as well.
8th May 2014, 11:55 PM #3Member
- Feb 2014
- Newcastle NSW
- 78
Thanks mate. I am using a unimig 140 inverter and the attempts were done at around 65 amps. stick and mig i can understand but tig is so different to me. tungstens are sharpened as you describe. i'll get onto it tomorrow and clean up the metal, slow the gas flow down and post again. Thanks again for your suggestions. this forum is invaluable!
9th May 2014, 07:59 AM #4
65 amps is low for that work, a general rule of thumb to start with for mild steel is an amp per thou thickness. Do you have any thinner stock to practice on, I'd start with 1/8" or 3 mm flat if you can get some.
If you want to start with the 5 mm stuff then clean it up bright and shiny, set the gas around 6 or 7 lpm and crank the amps up to 100 or more and then see how you get on.
When you sharpen the tungsten, make sure the grind marks run along the electrode, not around it.
Good luck.
9th May 2014, 11:00 AM #5Senior Member
- May 2013
- Gracemere
- 46
- 285
Miller weld calculator here http://www.millerwelds.com/resources/calculators/ will get you sorted. Even download as an app for your phone.
-Craig
9th May 2014, 03:28 PM #6
+1. What you had was way too high.
Take your time and watch the weld pool develop. If it's taking too long to develop, up the amps a bit and try again. On steel you can afford to take your time when practising.
Once you have developed a weld pool, dip in the filler and move a little bit forward, pause briefly, dip, move forward. Take your time.
Having a nice clear view of the weld pool helps a lot.
As you start to develop your skills you can up the amps some more and proceed more quickly.
BTW, take your time, don't try and rush.Cheers.
Vernon.
Some welds for you to critique
By Zumanity in forum WELDINGReplies: 20Last Post: 23rd Aug 2014, 11:30 PM -
Pretty welds
By Dave J in forum WELDINGReplies: 32Last Post: 15th Jul 2011, 02:37 PM -
How many welds?
By Single-phase in forum WELDINGReplies: 7Last Post: 24th Oct 2009, 04:23 PM -
first arc welds..advice?
By montiee in forum WELDINGReplies: 4Last Post: 29th Apr 2009, 08:44 AM -
In the name of learning...rate my welds
By JontyG in forum WELDINGReplies: 4Last Post: 2nd Dec 2008, 09:47 PM
