Results 1 to 10 of 10
    Jul 2006
    Athelstone, SA 5076
    4,258
    May 2011
    Murray Bridge S Aust.
    5,956
    have seen this at several shows, the bloke soldered aluminium coke cans with it. I bought some but never used it.
    Jun 2010
    Canberra
    1,322
    Yeah, I've seen these at field days for years, and have used them on the odd occasion with reasonable results. However, for the ones I have, you need to have a dedicated stainless steel brush for cleaning the joint before you braze. The ones linked to above don't seem to require this, and claim to be flux-cored, so perhaps they're different?
    Dec 2005
    South Australia
    1,657
    As said above similar rods have been around for years, I have used them on various jobs secret is extreme clealiness and don't overheat, can't see why you would destroy the hose by cutting the tails off you only need to split the crimps
    Jan 2007
    Katoomba NSW
    209
    I have these. They work great. Have welded up a few Ali things and I am not a welder by any stretch of the imagination.
    Built: a Bench,a Desk,an Archery Display,
    Those were the droids I was looking for.
    Jun 2013
    Brisbane
    4
    Default Aluminium Brazing
    My name is Mick from brazelikeapro.com. If you need any help with aluminium brazing, I would be glad to help.
    Jun 2010
    Canberra
    1,322
    Quote Originally Posted by Brazelikeapro View Post
    Well howdy there, Mick.
    First up, are your brazing rods any different from the ones we see at field days with the guy welding up soft-drink cans? I ask this because that system puts a great deal of emphasis on using a clean, dedicated stainless-steel brush to prep the joint, where with your system, not so much.
    Jun 2013
    Brisbane
    4
    Default Brazing Rods
    Quote Originally Posted by RustyArc View Post
    Hi RustyArc,
    Our rods are not the same as you see at the shows. Our rods are specially designed for brazing Automotive A/C components. They are a flux core rod and about 1.5mm thick. We don't have to clean parts with a SS wire brush. we do recommend all components are free of any oils.
    Jun 2013
    Brisbane
    4
    Quote Originally Posted by China View Post
    Hi China,
    The reason you should cut the tail off and braze a new tail on is because when you crimp a ferrule onto a tail, you get tail collapse. This means the tail is crushed in the middle and may not form a correct seal. This happens more on aluminium tails.
    Jun 2013
    Brisbane
    4
    Hi Eskimo,
    These rods are designed for brazing Automotive A/C components. I am happy to help you with your questions, if you need help.
  1. Aluminium brazing
    By kenny_10 in forum WELDING
    Last Post: 1st Nov 2011, 12:56 PM
  2. Brazing aluminium to metal
    By Tiger in forum WELDING
    Last Post: 28th Jul 2009, 08:00 PM
  3. Brazing
    By garym in forum METALWORK GENERAL
    Last Post: 9th Aug 2007, 12:12 AM
  4. Help with brazing with MAP
    Last Post: 5th Nov 2006, 03:28 PM
