Page 1 of 20 12345611 ... LastLast
Results 1 to 15 of 289
    May 2009
    13
    Default Is there an alternative to renting an argon gas cylinder?
    I do mostly stick welding to repair agricultural equipment on our farm, but have a MIG welder also using flux cored wire
    I'm wanting to occasionally use plain wire with argon gas sheild, but won't really do enough to justify renting a cylinder constantly
    Is it possible to purchase a cylinder and regs, and just pay to get it filled when it's empty?
    That way, once the initial purchase is made, it won't cost me unless I'm using it
    I live in Melbourne
    Liverpool, NSW
    44
    Try Speedgas, they sell argon cylinders. They are Sydney based but they may have agents in Melbourne.
    Speed Gas - Home
    Jun 2010
    Canberra
    1,322
    If you're wanting straight argon for some special application (aluminium?) then you don't have a lot of choice. However if you just want a shielding gas for normal MIG welding of mild steel, you can buy a 6KG CO2 bottle of Ebay - I paid $250 last year and the gas it came with lasted me about 6-7 months of intermittent use on a farm. Also had to cough up about $80 for a CO2 regulator/flow meter. I got it refilled at the local home brew shop for $70.
    May 2009
    13
    Quote Originally Posted by RustyArc View Post
    Is CO2 OK for MIG? I thought argon was recommended. I only weld steel at this stage. (I guess this question is a whole topic by itself on the forum, and has probably already been answered a hundred times!)
    Great idea with the home brew shop. Do they sell cylinders as well?
    Liverpool, NSW
    44
    For steel you need argon/CO2 mix. Speedgas sell this as "SpeedShield 5/2".
    Or you can hire bottles from BOC, Air Liquide, Supagas, etc.
    Jun 2010
    Canberra
    1,322
    "MIG Gas" is traditionally an argon/CO2 mix, but CO2 only works fine - it's a fiercer arc and not as good for very thin sections like car panels, but for stuff which is 1mm or thicker it works very well.
    Jan 2011
    geelong
    1
    you could try miter 10 or All Tools they sell small bottles of various gasses but they are one use only i don't think you can refill them.but for occasional use it might be the way to go
    Jun 2010
    Canberra
    1,322
    Quote Originally Posted by carlow View Post
    I think you need to buy a special regulator to fit them and they're a *very* expensive way to weld.
    Feb 2009
    canberra
    46
    I just thought People might be interested,
    I discovered that Gasweld sell the disposable SIP bottles for $25.90 each. that's about $15 less than I have seen them for anywhere else!
    https://www.gasweld.com.au/products/580053
    That's the URL to their web store for straight argon (i want it to try out tig welding), but I bought two of them in store, and they were the same price!
    its still more expensive than the big bottles I think, but its a damn site cheaper than anywhere else.
    May 2009
    13
    From the rather fuzzy label picture it looks like the cylinder volume is 950 cc and gas volume at atmospheric pressure 60 L
    Any idea how long that would last in a MIG welder?
    I still like the idea of the CO2 home brew cylinders
    Feb 2009
    canberra
    46
    The co2 is probably a good way to go, you'll probably get a lot more run time from that.
    I think the little bottles can last about an hour tigging (haven't tested it myself yet) . Not sure if mig uses similar flow rate or anything, you might get better run times, as the gas only flows when you are welding.
    Sent from my GT-I9100 using Tapatalk 2
    Sep 2010
    Lebrina
    1,914
    Quote Originally Posted by SimonP View Post
    Mig uses 8-10 lpm, so if you have a 60l volume you will get the grand total of less than 6 minutes welding. Not an option IMHO. However you are on the right track using straight CO2 gas.
    Feb 2009
    canberra
    46
    yea, I can officially say that those bottles don't last long at all.
    I had a play with the tig this morning, and the first bottle lasted about 20 minutes. Thats more than a dollar a minute!
    I thought I'd save the 2nd bottle for another day. I might try to stretch it out a little longer next time.
    Liverpool, NSW
    44
    Karl Robbers is 100% correct. Approx 6-8 minutes worth of MIGGING in one of those disposables. I've tried them and it makes no economical sense at all to use those.
  15. #15
    Feb 2009
    canberra
    46
    I find its crazy they even try selling the tanks. I guess enough people buy them for stores to keep selling them.
    Its a nice idea, they just need to be a lot bigger for the same price to be worth it if you ask me.
  1. E versus G argon cylinder pricing
    By WelderMick in forum WELDING
    Last Post: 1st Jul 2011, 01:19 AM
  2. How much Argon left in cylinder?
    By matt_o in forum WELDING
    Last Post: 28th Nov 2007, 06:00 PM
