Results 121 to 135 of 289
9th Mar 2015, 06:51 AM #121
I received a letter from Coregas today saying that welders supplies has gone into receivership and that therefore they would deliver to me directly. I am a high end user with one to two cylinders a year, ha ha...Funny because I returned my cylinder to Welders supplies some time ago and bought my own cylinder from a Speedgas distributor... go figure.
Civilized man is the only animal clever enough to manufacture its own food,
Barry Groves
9th Mar 2015, 04:56 PM #122Senior Member
- Jan 2015
- 211
my BOC Esized argon cylinder is almost empty and ive been looking into swaping and buying the cylinder from speedgas. has anyone done the swap and think it works out better? with boc being almost on ever corner getting gas anywhere is easy.
Currently im paying $207.90 rent per year with boc, and $167 to swap it each time.
The price of speedgas is $529 to buy and to fill is $159. so it is cheaper in the long run, but will take me 2 and a half to 3 years to be in front. I only use about 1 to 3 cylinders per year depending on what i have going on.
i was also looking at getting a D size bottle for my mig welder, which i rarely use, but was thinking if i own the cylinder then ill be saving there on rental.
i seems a bit of a no brainer to swap but just want others opinions who done the swap over.
11th Mar 2015, 10:27 PM #123Member
- Sep 2011
Gas price
If you are in Sydney you should ring around there are much better prices than people are quoting here ,You don't have to be a big user to get decent gas prices although the rent is a killer every body charges around the $200 mark per year ,Some of the smaller welding shops will do 3 month rental and no contract, as a general rule if as weekend warrior and small qty user you are paying more for refills than $110.00 inc gst for a G argon $60.00 inc gst for a g mig gas $40.00 for an oxy g then you haven't checked the market,An E size acet refill should cost no more than $80.00 although why everybody hasn't switched to lpg (buy the correct gear and it works) is beyond me
Long story short ring around the market has changed
12th Mar 2015, 06:32 PM #124Golden Member
- Feb 2010
- Ballina, NSW
- 900
12th Mar 2015, 10:25 PM #125Member
- Sep 2011
13th Mar 2015, 08:22 AM #126Golden Member
- Feb 2010
- Ballina, NSW
- 900
13th Mar 2015, 10:24 PM #127Member
- Sep 2011
I don't know about Qld or regional areas ,but a ring around in Sydney is worth it, its a buyers market at the moment especially with the introduction of the swap and go of industrial gases ,Gold coast has a few corgas depots ,what do they charge
15th Mar 2015, 07:21 PM #128Golden Member
- Feb 2010
- Ballina, NSW
- 900
Well there's swap and go here too, but I wouldn't call it a buyers market, in fact it works out for me that MIG gas cylinders are cheaper to rent than buy even though I'm a low volume user. Given your comments earlier I figured you must have secured a good deal from a specific supplier rather than just an observation that it was worth ringing around. My current rental is through a coregas agent... so the prices I get from them are as listed above.
27th Mar 2015, 12:36 AM #129
Most of you guys are lucky BOC is the only mob around these parts, speedygas want $100 each way freight here(50c a Km!) for a E argon and 140 refill yep 340 per bottle... BOC hit me for 192 per swap
It would be cheaper for me to drive down to Adelaide and swap using speedygas, maybe I should just buy 4 bottles and do 1 swap run a year....................................................................
28th Mar 2015, 01:04 PM #130Most Valued Member
- Sep 2010
- Lebrina
- 1,910
I found out this week that my employer is paying around $50 for a G size Argon mix. You could have knocked me over with a feather.
That is from the local Air Liquide agent.
We would be around the four cylinder a month mark - once I sort all the gas leaks and cut the fingers off whoever is turning the flow meters up flat out
I think I paid $158 for my last G size Argon four months ago.
28th Mar 2015, 03:58 PM #131Golden Member
- Feb 2010
- Ballina, NSW
- 900
28th Mar 2015, 04:10 PM #132Most Valued Member
- Sep 2010
- Lebrina
- 1,910
13th Apr 2015, 11:26 AM #133Senior Member
- May 2007
- South Australia
- 100
local Total tools now has Power10gas which is quite convenient, about 5 minute from home vs 15minutes and they are open all day Saturday and Sunday vs till 12 sat only.
23rd Apr 2015, 08:23 AM #134Senior Member
- Dec 2010
- Syd
- 492
10th May 2015, 10:18 AM #135Member
- Aug 2014
- North Queensland
- 80
Now own "E" Argon cylinder
Recently advised by Grahame Collins that Total Tools in Mackay, NQ now have Argon & Argon/mix available in D and E size cylinders. Ordered two "E" argons (one for friend) but only one left from first delivery. New supply arrived about ten days ago so drove down Saturday a week ago and picked them up. Approx 500Kms round trip.
Haven't used mine yet but my mate in Bowen started on his. Had to go to Townsville a few days ago and called into TTs there. No argon there but may be getting swap & go later this year which is different info to my enquiry earlier this year. About the same distance drive for me to either Mackay or Townsville but need to go to Townsville regularly so better if swap and go is available there. Even better if it ever becomes available closer, eg Cannonvale, Bowen, or Burdekin areas but probably not enough demand for this to happen.
Total Tools supplied by Power10 gases. Argon E cylinder (full) costs:New $479 and refill $159 for both Agron and argo mix. Probably not as cheap as available in large cities but only option we have here to avoid renting.
Called in to Grahame Collins place in Mackay and had a coffee and enjoyable talk to Grahame and his wife. Looked at his new shed shown in another post and all looks good with a nice size shaded outside work area.
E versus G argon cylinder pricing
By WelderMick in forum WELDINGReplies: 7Last Post: 1st Jul 2011, 01:19 AM -
How much Argon left in cylinder?
By matt_o in forum WELDINGReplies: 8Last Post: 28th Nov 2007, 06:00 PM
