Results 46 to 60 of 289
6th Oct 2013, 07:25 PM #46Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
the cylinders from speed gas come filled
https://www.nationalwelding.com.au/gas-c-460
6th Oct 2013, 07:43 PM #47Member
- Mar 2013
- Ningi Qld Australia
Thanks for that link, those prices are different from the ones I got from the Speedgas Qld branch and these are from National. I think that they apply only in NSW cause it's quoting me $289 delivery.
Ed.
6th Oct 2013, 09:01 PM #48Diamond Member
- Jun 2010
- Canberra
- 1,322
I'm getting a bit confused when trying to compare the economics of my 6.8Kg beer gas cylinder to the alternatives. For example, the first time I got it filled, it was completely out of CO2 and the homebrew shop guy wrote Tare: 13.55Kg on it before he filled it. I assume he added about 6.8Kg of CO2, so it would have weighed a bit over 20Kg when full. WelderMick pointed out in the previous page that this corresponded to 3,462 litres at standard temp and pressure.
So what letter size does this correspond to? Looking at that Speedgas site, their D size weighs 17.4 empty and 20Kg full, so 2.6Kg of gas which they say is 1,700 litres. Their E size goes from 32.2 to 41.6Kg, so 9.4Kg of gas or 4,000 litres of gas. Note that neither of the weight vs. litres match WelderMick's calculation, despite argon being a similar molecular weight to CO2.
6th Oct 2013, 10:09 PM #49Senior Member
- Aug 2009
- Quindanning, WA
- 175
I've seen the same numbers mentioned... 3463L for 6.8kg CO2 (at 0 degrees celcius and 1 atm) and 4000L for E size argon (at 1 atm and an unspecified temperature). I pay $30 for a CO2 fill vs around a $100 the last time i got argon so the economics seem pretty clear.
6th Oct 2013, 11:14 PM #50Golden Member
- Feb 2010
- Ballina, NSW
- 900
Are they all filled to the same pressure?
Oops... Stupid question on my part there. Yeah I get 1458 and 5271 litres (argon) in theory based on your figures above for the D and E bottles. CO2 is about 10% denser (so less volume for a given weight). The difference between STP and room temperature pressure is minimal, I think (something like 1%??).
18th Oct 2013, 04:21 PM #51Diamond Member
- Jun 2010
- Canberra
- 1,322
Just dropped past the local Gasweld who are flogging the Speedgas Swap'n'Go cylinders. It seems they also do CO2 "for welders over 250 amps". The D size CO2 cylinder is specced as 6Kg, whereas the Argon and MIG gas D cylinders are specced as 1.7m3. So why they use weight for CO2 and volume for the other gasses is a mystery. From memory, the volume was claimed at 15 degrees and 100kPa (i.e.one atmosphere).
D-size CO2 is $319 then $49 to swap, the latter is cheaper than the $70 or so the homebrew shop charge to refill my 6Kg. That said, my cylinder cost $220, so the $100 difference would take 5 refills to make up.
MIG gas D size is $339 but costs $99 to swap (same price for Argon).
18th Oct 2013, 05:22 PM #52Golden Member
- Feb 2010
- Ballina, NSW
- 900
Good info there Rusty.
CO2 will be liquid within the cylinder (just like LPG), so doesn't doesn't follow a constant pressure vs volume relationship. I guess also the fact that it is more of an 'average consumer' type of gas might mean that people understand weight better than expanded volume. I don't know, just thinking aloud.
18th Oct 2013, 08:25 PM #53Diamond Member
- Jun 2010
- Canberra
- 1,322
I think the penny has kind of dropped for me on the difference between CO2 and MIG/Argon gasses. CO2 enters its most "compact" liquid phase well within the pressure rating of the cylinder, meaning you can pack 6Kg in there. That's not the story with Argon, or a mix of it, meaning you can only get 2.6Kg or so into the same cylinder, resulting in less than half the amount of useable gas.
So provided you can live with the aggressive behavior of CO2, it's effectively a quarter of the price of a MIG mix in terms of how many litres of gas blow through the torch.
18th Oct 2013, 09:31 PM #54Golden Member
- Feb 2010
- Ballina, NSW
- 900
Yeah that's it. Still doesn't explain the Kg vs. m3 thing, but there's no doubt CO2 is way cheaper. Even comparing something like 100 argon vs. 93%/5/2, the mix seems quite a bit cheaper.
So I guess you're sticking with CO2? Which cylinder/reg combo do you use? I'm using argoshield at the moment but considering the swap.
19th Oct 2013, 05:03 PM #55Diamond Member
- Jun 2010
- Canberra
- 1,322
I like the idea of the nicer-looking bead profile you get with MIG gas, and the ability to work on thin sheet a bit easier, but the fact is most of the work I do is farm related using Duragal, and CO2 works really well, and with a bit of technique I can improve the appearance of the profile of the bead.
I got a 6KG Keg King cylinder of Ebay for $220 delivered (full of gas) and found a CO2 regulator/flow meter at Gasweld - I think it was about $80.
20th Oct 2013, 11:32 AM #56Golden Member
- Feb 2010
- Ballina, NSW
- 900
Have you got any info on cylinder life? are their any inspection/maintenance requirements for refills? One big plus with rental is that those aspects aren't my problem. I'm stuck with rental here in Ballina for my argon, which suits me because I use my TIG all the time, but I've found my MIG usage is much more sporadic - I'll use it flat out for a week, then not at all for a month or two (but I've got quarter of a tank left, so don't want to return the cylinder) - much better suited to having my own cylinder in that situation I feel.
Much of my mig is on gal 1.6mm RHS and 0.8 wire - how does this go with straight CO2?
20th Oct 2013, 03:45 PM #57Diamond Member
- Jun 2010
- Canberra
- 1,322
I'm going to guess off hand there's a 10 year thing, and that's one advantage of the Supagas swap'n'go setup - you don't have to worry about your bottle going out of date as you get a different one each time.
20th Oct 2013, 04:22 PM #58Diamond Member
- Jun 2010
- Canberra
- 1,322
And seeing as it's a lazy Sunday arvo:
40 SHS 1.6, 18volts, 6.5m/min
Bead width is due to me weaving a bit.
20th Oct 2013, 05:21 PM #59Golden Member
- Feb 2010
- Ballina, NSW
- 900
thanks Rusty, It looks like the main difference is with the bead profile on the fillet. With the 93/5/2 Ar/CO2/O2 I use, the fillet will tend to be concave if anything - but obviously depends on settings too. On my setup I'd be turning up the volts and wirespeed for that fillet to fill and flatten it out a bit. If you did that with the CO2 what would happen? would it be too hot and burn through?
20th Oct 2013, 07:31 PM #60Diamond Member
- Jun 2010
- Canberra
- 1,322
That setting is pretty much as hot as I can go without blowing holes while allowing me to weave a bit to flatten out the profile a bit. At 20V 8m/min I have to do a straight, fast run which results in an even more convex bead.
The same run with stick (when I get it right) produces a concave bead with nicely wetted edges. I think the less attractive bead profile is one of the main drawbacks of CO2.
E versus G argon cylinder pricing
By WelderMick in forum WELDINGReplies: 7Last Post: 1st Jul 2011, 01:19 AM -
How much Argon left in cylinder?
By matt_o in forum WELDINGReplies: 8Last Post: 28th Nov 2007, 06:00 PM
