Results 1 to 4 of 4
Thread: tig for silicon bronze
9th Apr 2011, 09:51 PM #1
Hi all,
I have a Dc inverter tig machine ( Weldmaster 180 HF) and want to tig silicon bronze. Will this machine do it or do I need an AC machine? Any source for silicon bronze filler rod?
regards,
ADwww.denmanmarine.com.au
Australian agent for Swallow Boats, Bruynzeel Multipanel Plywood and Barton Marine Products
9th Apr 2011, 11:30 PM #2China
- Dec 2005
- South Australia
- 1,656
BOC have silicon bronze filler rod as for the other question I will be interested in th answer also
10th Apr 2011, 11:06 AM #3
DC. Silicon bronze is great to use and has a lower melting point and less heat is required on the base material. It is a bit pricey particularly when you get into the 3.2mm size wire. You also have the benefit of powder coating and even zinc plating.
10th Apr 2011, 03:43 PM #4
Gidday
You can use both DCEN or AC............Using alternating current will give you a much better weld finish n more fluid weld pool..... from memory theres a bit of info about welding with silicon bronze here:
Tig welding with silicone bronze
and a supplier:
http://www.welder.net.au/products.ph...s+%26+Gas+Rods
Regards LOuJust Do The Best You Can With What You HAve At The Time
