Results 1 to 5 of 5
22nd Mar 2011, 09:10 AM #1New Member
- Jan 2011
- Rocky Gully WA
- 1
is it ok to use dc inverter welders with a generator?
Hi, just wondering if running a cigweld 130 dc inverter welder off a generator will harm the electronics of the welding unit? Cheers
22nd Mar 2011, 06:17 PM #2
Hi ,
My thoughts on this are that it would very much depend upon matching the capacity of the generator to the draw by welding machine.
A person with an electrical background is much better suited to answer this but for something like a 130 amp welding machine maywell need something like a 4 kilowatt generator to drive it.
22nd Mar 2011, 06:42 PM #3Member
- May 2008
- 79
Genset use for inverter welder
Hi,
You can use genset to power a welder if you adhere to three fundamental rules.
1. You must ensure it has an A.V.R. , this is an automatic voltage regulator and is used to maintain a steady output voltage especially when the load varies constantly. i.e you strike and arc, it loads up then you break the arc and it unloads. Avoid self exciting alterntors......Kabm.
2. The genset must have sufficient capacity to provide power for the welder, have overhead for power factor most notably a lagging current caused by inductive load and further overhead to allow for efficiency losses. Basically for a machine that can deliver 130 amps output for arc welding you would consider 4.5Kva capacity as the absolute minimum. I would reccommend seeking advice from BOC as to their reccomended size.
3. If you are going to use an extension lead ensure it has 2.5mm^2 (2.5 square millimetres) cross sectional area of copper within the conductors to avoid voltage drop. Most likely you would need to make one as the 15 amp leads from the big hardware chains contain 1.2mm^2 conductors.
Pete (Tokentools)Last edited by inverter_weld; 22nd Mar 2011 at 06:44 PM. Reason: correct my spelling - fat finger typist syndrome
22nd Mar 2011, 07:02 PM #4Diamond Member
- Jun 2010
- Canberra
- 1,322
A while back I tried out my BOC Smootharc 130 inverter on a cheap-arsed 2kVA Bunnings generator - with a careful strike I was able to weld at about 80-90A.
I've got to say I never considered whether it was bad for the welder - I've always regarded inverter-style machines (or any switching power supply really) to be highly tolerant of variations in input voltage.
22nd Mar 2011, 09:07 PM #5Electrician
- Sep 2007
- Thailand
- 62
- 33
It appears as though the minimum recommended generator size is 6kVA. This size would allow the use of 'brushless' generators (poor voltage regulation & poor output waveform).
See the below image, which comes from http://apac.thermadyne.com/IM-Upload...29%20Final.pdf“I do not think there is any thrill that can go through the human heart like that felt by the inventor as he sees some creation of the brain unfolding to success... Such emotions make a man forget food, sleep, friends, love, everything.” - Nikola Tesla.
Honda Generator
By timbo123 in forum METALWORK GENERALReplies: 5Last Post: 24th Aug 2006, 12:20 AM
