Page 1 of 5 12345 LastLast
Results 1 to 15 of 66
    Jul 2010
    perth wa
    42
    Default 4' or 5' angle grinder
    before the fire in my shed i felt a vibration in my 12$anglegrinder from wa salvage and i was going to mreplace it but i dont know what size to buy
    Aug 2009
    Quindanning, WA
    175
    I have one of each... 4" with a grinding wheel for grinding because I find it small and easier to handle and 5" with 1mm cutoff discs for cutting because the cutting discs for the 5" cutoff wheels last a lot longer than the ones for the 4".
    Apr 2002
    Brisbane
    429
    A good 5" grinder is a lot more grinder..usually more powerfull and a bigger wheel, and more cutting depth.
    A 4" is a bit lighter and definitely better for getting into fiddly spots
    I currently have 4 grinders.....the 5 is a much faster job than the 4
    cheers
    Any thing with sharp teeth eats meat.
    People are made of meat.
    Jul 2008
    Lismore, NSW
    54
    As has been said, a 5" is best. I have a 5 with a 1mm cutting disc and it's a world of difference
    over the 4" with the same disc. I still like my 4's for grinding though.
    Don't purchase a cheapie though. Go spend atleast 100 bucks and it will last a long time.
    If you have the cash, spend about 350 bucks on a good Bosch 5" 1500W or Milwaukee 1500W beast.
    They have good features like soft start and anti-jam and don't bog anywhere as much when loaded
    crowie's Avatar
    crowie is offline Life's Good, Enjoy each new day & try to encourage
    Dec 2009
    Faulconbridge, Lower Blue Mountains
    68
    64
    G'Day Wodstok,
    A number of years back I worked in an engineering maintenance company, while the blokes liked to use the 4" angle grinders for reasons of lightness and manoeuvrability, I had to implement a monthly service plan for them for 2 of the 6 to ensure they kept working.
    The 5" angle grinders weren't available.
    For similar reason the boiler maker was using a 7" angle grinder rather than a 9" angle grinder.
    I personally have 2 x 4" angle grinders for light duty works [an older AEG plus a Makita] and a 5" angle grinder for heavier work [Falls Miller] plus a 9" grinder for big work [Bosch].
    It's a matter of assessing what you are going to be doing and not overwork the grinder [even give it a time of free running after heavy workout to allow the motor to cool before stopping].
    On the issue of the 1mm cutting disc's, please always let the disc do the work and never use them to grind as they only have 2 reinforcement layers of fibreglass.
    All in all always take care with grinders.
    I hope I haven't rabbitted on too much.
    Cheers, Crowie
    Jun 2010
    Canberra
    1,322
    5" without a doubt - with 4" you're only half way through a disk before you're hitting the gearbox.
    Aug 2004
    Lost in Space
    53
    331
    All we generally use use @ work is 9 & 5inch grinders..................they give the best performance and bang 4 your buck!
    If you can get a good quality 5inch (Bosch,Makita,Hitachi) Under anything but the most demanding continual use you'll find it'll last a lifetime!
    Regards Lou
    Just Do The Best You Can With What You HAve At The Time
    Jul 2010
    perth wa
    42
    i have started working at the local bunninga (bibralake) and i can get a 5' makita for $99 ant i get 20% off the proffite so i think i mighe get that one.
    thanks
    tom/wodstok
    Jan 2004
    Mackay North Qld
    6,446
    With 4 and 5" angle grinders its clearly price against quality.
    Generally most 4 " grinders have less power, internally fitted brushes and bush bearings.
    Being cheaper they fail earlier than the 5" models.
    The 5" jobbies are more powerful, have externally replaceable brushes and roller bearings justifying a higher purchase price but ensuring longer life.
    Add to this the extra refinements that appear at this size /level of A/Grinder such as soft start and even the ability on a certain Hitachi model to run on Ac or DC power ( if you have never burnt up a grinder on a generator not running the correct revs you won,t know what I mean)
    Go 5"with as many watts as you can find.
    Dec 2007
    Sydney
    109
    5'' better. Glad I bought that size. the 4'' is just a little too small and consumables go too quick. Then there is power factor etc. My 5'' has done everything I have thrown at it. I'm amazed I didn't have a grinder in the arsenal until about a year ago. Flap discs and 1mm cutting discs for the win as well.
    May 2006
    Sydney
    48
    13
    I bought a 5" makita for $99 at the big b. Was DOA so took it back and got a bosch. Hasn't missed a beat so far, and I've given it a hard life grinding away bricks as well as metal.
    You will find the $99 grinders are fairly weak in power. I would be spending more money and getting one with more power, as you will notice the speed slow down when grinding.
    Tom
    Apr 2002
    Brisbane
    429
    Quote Originally Posted by montiee View Post
    How are you suposed to injure your self properly without a grinder
    I've had the grinders out last couple of days......it always surprises me how much more go the 5" has than the 4".
    OH yeh.... those flap disks are a wonderfull thing.....very versatile and controlled agression.....I've been using them for a lot of stuff I would have previously used a grinding wheel for.....
    cheers
    Oct 2008
    Mid North Coast NSW
    45
    177
    5" Cutting, 4" Grinding
    I have a 5" Makita and a 4" Bosch. The $85 blue Bosch kits are great, can't kill em, plenty of power.
    Apr 2010
    Rural Victoria
    358
    IMHO you should go for the Metabo 5" with variable speed. Heaps of grunt and reliable.
    You will throw the flap discs out the window when you can slow your ginder down and fit a sanding disc. Nothing looks better than a weld sanded flush especially if presentation is important. It is all too easy to put unwanted gouges into the material even with a flap disc.
    Might be a bit exxy for your taste at around $300......
  15. #15
    Dec 2007
    Sydney
    109
    Quote Originally Posted by Gerbilsquasher View Post
    I have NEVER EVER gouged using a flap disc. How one could do so is just unbelievable given that flap discs are flexible and mould relatively around what's being essentially sanded away. Old fashioned grinding discs yes you can gouge, not flap discs.
  1. What size angle grinder ??
    By PlanePig in forum METALWORK GENERAL
    Last Post: 29th Apr 2009, 08:55 AM
