Results 1 to 7 of 7
Thread: ESB Pulse Mig
6th Dec 2009, 09:17 PM #1New Member
- Nov 2009
- Penshurst
- 1
ESB Pulse Mig
Have the possibility to purchase a used ESB Pulse Mig. The only thing is that something seems to be wrong with the wire feed.
The wire feed is not constant and slows down / speeds up randomly.
Hope it would only be an easy fix... any hint where to start looking for a solution to this?
Daniel
6th Dec 2009, 09:29 PM #2
I fixed one of those, normally the drive board is quite simple, but the usual fault is people pulse the wire feed and the motor dont like it. From memory I replaced an SCR a chip and several other bits, I bought 2 of each for the guy as spares because the postage at $9. 50 was the expensive part. He bought the motor which from memory was $50 or so bucks. That was 2 years ago its still welding now and he welds as a trade.
6th Dec 2009, 09:40 PM #3
There are 2 possibilities there,
99% of mig problems are mechanical.Look for the simple things first.
1. Examine the wire spool and check it for surface rust.If rusty its likely that as the spool is pulled around by the wire drives, that the top rusty surfaces slip somewhat. When the the bottom surface goees through the drive where the is less rust, it goes faster as there is more grip.
2.The other possible cause is there is a switch control somewhere that turns of the drive for a set time and turns it on again. Different switches on different places on diffrent machines ,so you will have to look carefully.
Can't recall the layout for ESB but it will be there if its a pulsed machine.
The setting may even be electronically adjusted,I do not know for sure on that one.
Get the model and do a search on the net for a downloadable manual.
6th Jan 2010, 01:11 AM #4danielson
- Dec 2009
- broadford
- 63
- 213
here is my two bobs worth,the first thing you look at is the liner in the gun lead,if it is in need of replacement it will bind up the wire with the slightest of movement of the gun.classic symptom is thwire feed slows and regains speed and slows again causing backburn and tip fusion.a cheap and easy maintenance issue that needs to be done sooner or later anyway????
6th Jan 2010, 07:38 AM #5
If the coil of wire is contaminated with grinding dust or rust its a waste of time just changing a liner as it wont be long until ther replacement is as bad as the original.
Alternately ,the wire can have a wiper placed on it. A simple trick is an ear plug(old E.A.R. brand ones work best ) with a razor slit lengthways and placed over the outgoing wire prior to the wire drive.
Cleaning the mig liner rather than replacing it,is acheived by rinsing it in kerosine , then methylated spirits to dry off the kerosine.
For those of us that live in humid areas ,the wire if left on the machine will rust within a week, particularly with a coating of metallic dust (from the grinder ) coating it.
When not using your mig put a garbage bag over the wire with some desscicant in the bag.
I hope this helps you.
6th Jan 2010, 07:18 PM #6danielson
- Dec 2009
- broadford
- 63
- 213
another trick is to fold a piece of felt over the wire between spool roll and wirefeed motor inlet guide and place a clothespeg on the felt under the wire,it hangs nicely.we will have to agree to disagree on washing out liners graham,ive never seen anything that will succesfully remove the crud/copperwash from a mig liner and put liner back into viable service,especially when a replacement part is often only $25-$35 dollars and will last one to two years on an industrially used machine
6th Jan 2010, 09:19 PM #7
Daniel,
All I can say the process worked for me.I was a shift welder in the nickel pipe welding bay at QAL Gladstone for a few years.
This was a procedure in the time that I was there.
I cleaned my liner every couple of days before the crud got a grip.
All I tended to forcefully inform anyone -who pointed their grinder stream at my wire feeder- of the error of their ways. Units with uncovered spools tend to cop it as the hot sparks imbed in the wire coating.
Migs are mechanical more than electrical in their failures. Too many operators machines (see inside of their wirefeeders) are like pigsties. No wonder they have problems.
Nickel pipe butt joints were fully certified pressure vessel joints and as such each one was radiographed.
I never failed a single joint in the three hundred or so that I welded.
I have also used the same procedure for LW1 GMAW wire in certified carbon alloy pipework and had no problems.
Most liners in my experience were replaced due to some wally kinking the liner by dropping something on it.
I did not mention that the air was used to blast through the liner in the direction of wire feed after the kero,then again after the metho.
Liner cleaning should be a maintainence procedure not a repair procedure and must be done on a regualr basis.
Having said that I always kept a set of spares in my tool locker, liners,insulators, gas diffusers shrouds and most importantly spare contact tips.
MIG pulse welders
By vin in forum WELDINGReplies: 12Last Post: 22nd Dec 2008, 10:35 PM -
DC Pulse TIG and Aluminium
By Steph TIG in forum METALWORK GENERALReplies: 4Last Post: 3rd Dec 2008, 08:41 PM -
double pulse?
By northerncat in forum WELDINGReplies: 2Last Post: 22nd Nov 2008, 08:18 PM -
pulse migs
By northerncat in forum WELDINGReplies: 6Last Post: 1st Oct 2008, 08:11 PM
