Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Oct 2007
    Sydney
    3,112
    Default Where to find hydrochloric acid?
    In a DVD by Covell he shows using muriatic acid to clean off zinc plating. I've often had small objects such as nuts and bolts I've wanted to tack on with a TIG and have been tediously grinding/sanding the plating off. Notwithstanding the cautions of using acid, a simple process of just stripping it all off would be perfect. I believe this is hydrochloric acid, is this freely available and if so from where? Is it as effective at cleaning metal before welding as the Covell DVD implies. If you haven't seen the DVD he simply dips the part in the acid then neutralises with water before drying and welding. Again, I appreciate the cautions of using strong acids having seen what sulphuric acid can do!
    Pete
    Mar 2008
    Nth Qld
    68
    Try any pool shop for a bottle of HCl. Used to release the chlorine molecule for keeping the bacteria down
    regards,
    Jill
    Jul 2004
    Sale
    68
    2
    Its sold in hardware stores as spirits of salts, anything from about 500ml to around 15 litres. Be careful with it though, it is highly corrosive to skin, eyes, tools, concrete, clothing etc etc. It really is a case of follow the instructions and use appropriate protective clothing, particularly to the eyes and hands, and exposed skin in general.
    Mar 2008
    Nth Qld
    68
    And if diluting the acid, always add the acid to water, and NOT water to acid. And be very careful of splashes. It is surprising just how much splash you can get simply pouring the acid in to a bucket of water, so follow johnc's excellent advice about protective gear, especially around the eyes
    Joill
    7,189
    At work we make extra highly concentrated (13.6 molar) HCl by dissolving pure HCl gas in chilled high purity water. The resulting acid produces a violent reaction when it contacts a metal like Zn and it instantly foams up like a CO2 fire extinguisher.
    We also purify fuming grade (12 molar) HCl by distillation. This produces a small amount of residue which we normally discard so can access this if I want to. The residue is not full strength (~9 molar) because the distillation process drives off some of the HCl gas but it's still more than concentrated enough to dissolve the Zn off steel.
    Just be aware that dissolving Zn plating happens very quickly (~10 minutes) so make sure you keep checking - if you walk alway and leave it you can come back to a pile of black sludge and have dissolve everything ie the Zn and Steel. Even with the HCl you buy at the hardware it will also foam up but not so quickly but it's still a good idea to place the container of HCl inside another container or tray so the foam doesn't leak out all over the place. I use a plastic lid from a plastic storage tub as a work tray.
    Mar 2008
    Newcastle West Australia
    197
    Pete, why not just buy black nuts & bolts etc?
    PS I think Bummings sell Hydrochloric.
    www.solidwoodfurniture.com.au
    A good edge takes a little sweat!!
    Oct 2007
    Sydney
    3,112
    Quote Originally Posted by Claw Hama View Post
    It's difficult enough to buy metric nuts/bolts in this "metric" country of ours as it is TIG requires perfectly clean surfaces anyway.
    Thanks, sadly I'm off to Bunnings today (I loathe that place) so will try to get the acid there. I'm not sure what strength Covell was using in the DVD, I'll watch that part again this morning, but it was definitely quite an intense reaction!
    Pete
    Mar 2008
    Nth Qld
    68
    Why not call in at a pool shop and get a bottle of acid , rather than raise your blood pressure at Bunnings?
    Oct 2007
    Sydney
    3,112
    Quote Originally Posted by JillB View Post
    Unfortunately I have to go down there for some other things so will probably just grit my teeth and do two in the one hit Thanks for the heads-up on the pool suppliers though, not having a pool I wouldn't have known.
    Pete
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    From memory HCl is what brick cleaners use. Obviously a quick check of the label will confirm this in case I'm leading u astray.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    Jul 2005
    Here, in Katoomba, 'cept when I aint.
    63
    704
    Yeah, our local Bunnies sells it.
    But, AFAIC, JillB's on the right track. It was much cheaper to buy through our local pool supplier.
    I may be weird, but I'm saving up to become eccentric.
    - Andy Mc (AKA "Ghost who posts." )
    scooter's Avatar
    scooter is offline
    Super Moderator
    Dodgy brother
    May 2004
    Outer Melb SE suburb, Vic
    54
    719
    Quote Originally Posted by jatt View Post
    'Tis correct.
    Cheers.............Sean
    The beatings will continue until morale improves.
    Oct 2007
    Sydney
    3,112
    Yep got it at Bunnings today, no drama at all. Not sure if it's required to clean the piece additionally after the acid, I did as it seemed to still have a bit of a layer of "something" on it but it would be handy to not have to.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Buy your Hard to get Metric Items from an Engineering suppliers EASY.
  15. #15
    Oct 2007
    Sydney
    3,112
    Ha ha, yeah right. Last time I bought a few metric bolts from the guy down the road he charged some outrageous amount each. I thought he was joking, but the joke was on me! It was almost worth a trip down to Coventry and they're hardly a 2 dollar shop either!
    Lucky for me I get up to Singapore and Hong Kong regularly and often come back with a stack of metric nuts/bolts to restock my store
  1. Hydrochloric acid for Damascus?
    By ohno in forum METALWORK GENERAL
    Last Post: 10th Oct 2006, 09:49 PM
